Home > Maintenance & Modifications > ** Update Returning ** -Fitting NAS style plinths
Page 2 of 3 <123>
Martin
Site Admin
One option is use the SVX type bases which have the screw holes in (LR009773)
These are about £13 each, and have a nice bit of foam on the back to cushion the bodywork.
Or you can adapt the OE NAS plinth (AMR3850 but the version available without the captive bolts) and drill two holes for mounting screws
These are about £4 each, no foam on the back.
However, at the upper side/brake lamp position, you can't get a drilled AMR3850 NAS base aligned correctly due to the large opening in the middle (it is large to clear a filament bulb holder). It sticks out past the edge of the capping.
The SVX plinth has a smaller centre hole than the NAS base, and as you can see from the pic, a variety of mounting holes are available to get the lamp to sit in board (well, right on the edge) of the capping.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #567306 28th Sep 2016 1:25pm
Stacey007
Thanks,
I may go for these,
CNC machined mounting plinths Made from aerospace grade 6082-T6 aluminium
But in black and they come with the correct holes and seal, plus a little less deep
Post #567310 28th Sep 2016 1:57pm
Martin
Site Admin
Never seen those before Shocked  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #567311 28th Sep 2016 1:59pm
Stacey007
^ Is that good or bad though....
£20 each (poss a bit less as a deal with the lights) but if its £14 for a plastic job and they fit 100% its a bit different?
Post #567318 28th Sep 2016 2:18pm
Martin
Site Admin
Just wasn't aware someone was making aluminium copies Smile
You only need the SVX ones on the top corners, the £4 ones (with holes drilled) are perfect at the bottom.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #567319 28th Sep 2016 2:28pm
mk1collector
Where are the Ali ones from? I like them. Ray
My build thread
Post #567339 28th Sep 2016 3:49pm
Stacey007
PM sent.
I like the look, bit different and lets face it with these cars that's hard to find these days..
Very Happy
Post #567363 28th Sep 2016 5:18pm
Stacey007
Also
If you have a swing out rear wheel being slightly less deep than oem means the wheel will not touch.
No problem for me as I don't but could help?
Post #567364 28th Sep 2016 5:23pm
mattp
Australia 2016 Defender 110 Puma 2.2 SW Santorini Black
I don't mind those, it's a shame they don't fit the genuine Perei lights. I wonder why?
Post #567485 28th Sep 2016 11:55pm
Le Perei, hmmm, not a brand I'm a fan of.
If they are anything like the b...s up like the number plate light then they are rubbish.
Wipac and RDX on the other hand, faultless. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #567526 29th Sep 2016 10:49am
Martin
Site Admin
In my experience with NAS filament lamps: Wipac - awful, filled with water. Perei - great, only needed changing due to UV discolouration.
I have gone Perei for my rear LED conversion, very happy 18 months in. The Wipac and RDX etc offerings in LED 95mm look tacky in comparison (in my opinion). Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #567530 29th Sep 2016 11:13am
Might depend on actual lights, mine are OE style not NAS.
So I know what you mean with NAS spec Wipac's they are chrome like.
My fog and reverse I wanted RDX LUX, some companies kept not describing properly and sending me Wipac's they looked like a Christmas tree bauble. Shocked
The Wipac number plate light IMO is superior, and personally I only like SMD LED's.
But that is just me, most last well but it's the look that is more personal taste. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #567532 29th Sep 2016 11:26am
Stacey007
I'm never going to get a £600 set of rear lights round the financial controller...
Compared to £250 (with the alloy plinths and front wing indicator lights)
I'm still unsure about clear to be honest but I have to choose something....to go with the front look.
On my car I guess they will look like this.. as its black. I do quite like it.
to tone down the 'Bling' look I also thought about these guards..colour coded to my car in Santorini.
At the end of the day, if I'm not keep I can swap them Thumbs Up
Post #567536 29th Sep 2016 11:36am
Martin
Site Admin
One option for you could be:
Clear LED stop/tail (SVX type)
White lenses for indicators, silvered bulbs
Clear LED fog light (SVX type)
It depends if you like the style of LED lamp with "discrete" LEDs on the surface (very much not discreet!)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #567541 29th Sep 2016 12:00pm
Stacey007
^ Have you any links to show these please?
I never thought there could be so many different options choosing lights...
Thanks
Post #567544 29th Sep 2016 12:05pm
Page 2 of 3 <123>
