Home > Td5 > 2006 TD5 dash repair...
JOHNT01670
United Kingdom 2006 Defender 90 Td5 SW Zermatt Silver
Before I proceed with a purchase I thought I would ask if anyone had any problems installing the raptor dash over panels or any pics of one in situ?
My head unit casing is broken and the replacement OEM part as far as I can see is about the same as the raptor panel.
Advice always appreciated folks.l
Post #567258 28th Sep 2016 9:11am
Tiger
Surely that will be a right pain?
Isn't the raptor deisgned for Pre Td5 Dash Facelifts?
The LR part is about £40 from memory for black and £80 for the Silver one
but what about the Mud Stuff front?
http://www.mudstuff.co.uk/products/mud-stuff/td5-facia-plate.html
£15 and would sort out a busted radio facia
Post #567283 28th Sep 2016 11:24am
JOHNT01670
Cheers for pointing this one out - hadn't found it whilst looking around
It will certainly cure the problem and a sensible price too!!
many thanks again
Post #567301 28th Sep 2016 12:12pm
mactheknife
United Kingdom 2004 Defender 110 2.5 TD CSW Baltic Blue
I have the raptor fascia, its perfectly made, aside from some nubs left over from the cutting process. However the spaces for the switches are more perfectly aligned than the actual ones on the dash, which means a few switches can look out of line and also rub slightly. Dependent on how OCD you are about these sort of things it can be no issue or an irritation.
I chose the "fettle a bit, live with the rest" approach as it holds a double din firmly. The full fascia looks better than the partial one to me.
Post #567454 28th Sep 2016 9:13pm
JOHNT01670
Thanks,
Reply appreciated
Post #567475 28th Sep 2016 10:08pm
JOHNT01670
Fixed!!
Post #570671 13th Oct 2016 6:15pm
1978
United Kingdom 2003 Defender 90 Td5 HT Belize Green
I fitted a raptor dash panel and replaced the cigar lighter with a blue sea USB socket a few nights ago, really pleased with both products.
Apologies for the awful photo!
Post #570741 13th Oct 2016 9:10pm
JOHNT01670
Nice job!! Thumbs Up
Post #570931 14th Oct 2016 9:13pm
1978
Thank you, yours look great too! I wasn't aware of that panel, looks like a good solution to a terrible bit of design from Land Rover! Thumbs Up
Post #570935 14th Oct 2016 9:24pm
