Home > Technical > Fan noise
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
Fan noise
I can hardly believe I am writing this, however has anyone else noticed how loud their interior fan noise is?
On the first speed it is a slightly annoying 'asthmatic' wheeze, but is more apparent than the engine noise!
I never heard this in a TD5 Defender (no surprise there) but if no one else has the issue I may get the dealer to look at it.
Post #5651 21st Dec 2008 7:45am
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
The fan is noisy but I am used to the Disco. (The Disco's fan used to switch itself off on speed 4)
so (see the heated seat thread elsewhere here) I wind down the windows so that I can't hear it.
(A Merry (not white) Christmas from the antipodes Very Happy .) Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #5653 21st Dec 2008 9:33am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
The fan is noisy as you said. But what annoys me more is the fact that the with the A/C or the wipers on I get noise generated from their motors to the radio transmitter I use with my iPod. There is obviously very poor suppression on the cables in the dash.
I do like the way a fan comes on with just the A/C switch pressed in.
As for a white Christmas its a bloody cold 28C today and bucketing down rain for most of the last 24 hours. So much for camping over Christmas Sad 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #5655 21st Dec 2008 11:48am
mse
The fan does have a noise...i dont get the interference, but what does annoy me is it doesnt turn off with the ignition Mike
Post #5663 21st Dec 2008 5:12pm
dm_td5
Do you mean it stays on when the ignition is in the ON or ACC position? The three Pumas I've driven were all like that but so were my Disco's. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #5666 21st Dec 2008 8:35pm
Sticky
As above, my definately turns off with the ignition.
Thanks for setting my mind at rest about the fan noise, there are all sorts of noises I probably hadn't noticed before with the TD5
Post #5667 21st Dec 2008 9:08pm
solmanic
Australia 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I only find the fan noisy when it is on recirculate - it's not to bad when set to fresh air. 2007 Defender 110
1970 Alfa Romeo 1750GTV
Post #5674 21st Dec 2008 11:44pm
mse
I think (ots been a while) it stays on when either in position 1 or 2...either way the 3 ive been in did it and all the other LR products ive been in/owned dont.
never mind either way Mike
Post #5683 22nd Dec 2008 5:34pm
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
I'm not sure it's the actual fan that's making the noise, it sounds to me more like the airflow itself, as the air gets forced around sharp bends and through small holes (like a whistle with no, well whistle). As "sticky" say's, an asthmatic wheeze. The quieter engine doesn't help as other noises then become more apparent.
Bosun.
Post #5700 23rd Dec 2008 7:21am
Grockle
Sticky,I mentioned this quite a while ago on this and other forums,you can't do anything it's down to the speed of the fan even on speed 1.The TD5 venilation is quite alot different to the TDCI. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #5709 23rd Dec 2008 12:18pm
