Home > Technical > Fitting VUB500890 kit questiond
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Fitted most of the Longrange subject driving light kit to my 2003 TD5 today, however in step 49 of the IKEA like pictograph Land Rover instructions, you are supposed to tap into the back of the instrument pack with a blue/orange wire from the kit..... I think it might be from the relay live......
Only problem is that I do not have a blue/orange wire anywhere on the back of the instrument pack plug assembly.
Should I be tapping into the high beam/ main beam warning lamp wire......which according to the 2002+ TD5 wiring diagram, should be blue and white. Was there a change between early and late TD5?... The pictographs clearly show a TD5 dash.
Anyone have a wiring diagram of what each wire is supposed to connect to? These instructions are pretty hopeless when it comes to verifying the connections.
Patrick
Fitting instructions here.....http://www.defendercenter.ch/VUB%20500890%20Zusatzscheinwerfer.pdf
Post #564889 18th Sep 2016 8:09pm
dorsetsmith
the fitting information for MY 2007 onwards
blue/ orange = UW blue white td5 MY 2002 Main beam warning on instrument pack plug assembly
Post #564928 18th Sep 2016 9:03pm
Justtellme
Thanks! That confirms things.....I was planning to tap into the Blue/white at C0233-1 if I wasn't able to sort out the colour disparity, so now I'll start splicing with confidence!
Patrick
Post #564993 19th Sep 2016 5:54am
