![]() | Home > Maintenance & Modifications > Mud Interior Side panels |
SingletrackFred Member Since: 23 Mar 2015 Location: Reading Posts: 66 ![]() ![]() ![]() |
Good job, looks much better.
I like the Mudstuff bits. The vent is excellent, and have the cubby box tray. Both are excellent fit, useful and well priced. |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2321 ![]() ![]() ![]() |
Good job Lew, I like Mudstuff bits too.
Swac3 Member Since: 21 Feb 2015 Location: Aberdeen Posts: 363 ![]() |
Aye they look good even better i'd guess if you added the rear headlining but its pricey, whats with all the strips of silver/foam ? was that in the truck when you got it or is it something you're doing? 3 Landrovers
Lew-M Member Since: 04 Apr 2016 Location: North West Posts: 95 ![]() ![]() ![]() |
Thanks guys, I'm happy with how they look, and after a quick drive today the sound proofing seems to have worked a treat! Swac, the strips are sound deadening, a foil and butile strip, much the same as the brand dynamat. Total coverage isn't required as they are there to stop resonance in the large panels, the closed cell foam which will go on top will add a more wholesale insulation! A couple of strips added to a door or footwell for instance make a remarkable difference!
Ahh, only really see it done in full sheets on here, but makes sense. 3 Landrovers
