Home > Td5 > Td5 no go past 70
Page 2 of 2 <12
lightning
Is the performance still good below 70mph?
With a stage 2 remap it should pull very well through the gears.
Will it rev up towards 4,000 rpm in (say) third gear?
Post #563405 12th Sep 2016 5:32pm
oakworthboy
United Kingdom 2004 Defender 110 Td5 PU Coniston Green
Performance is fine lower down the Rev range, I tried to go round a bus earlier in 3rd, did the same at higher revs.
Post #563438 12th Sep 2016 7:12pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I don't know if it's worth looking into a rolling road so they can diagnose it. Changing parts can get expensive.
I've found sometimes it's better to bit the bullet and get a specialist to check it out. I tried changing all kinds on a motorcycle a few yrs back trying to get it to pull on the motorway. It turned out to be a fault rev limiter in 3rd onwards. I changed carbs and coils several times in a effort to sort it. A rolling road had it done in less than 30 mins 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #563446 12th Sep 2016 7:31pm
roel
Do you have a way to measure the turbo pressure?
Does it get to high and the ecu goes in limp home mode?
Or does the pressure drop suddenly? Then you could have a hose problem. Roel
2003 90 Td5 (2009-now)
Post #563552 13th Sep 2016 6:39am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
clearing all the fault codes first and have a run again.
I've seen that happen on the few of the Td5s that i touched. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #566027 23rd Sep 2016 11:00am
Page 2 of 2 <12
