Home > Td5 > Td5 no go past 70
oakworthboy
United Kingdom 2004 Defender 110 Td5 PU Coniston Green
Td5 no go past 70
Hi everyone, i have a 2004 defender 110. Stage 2 alive remap and uprated intercooler. This week on the way to work when i get to around 70 the power goes, like its hit a rev limiter. Cant go over 70. Lift off the pedal and i have power again. Accelerate again and same problem. Cleaned the MAF, MAP, changed the fuel filter and fitted new silicone hoses. Tried driving with the MAF disconnected still the same, no misfires or lumpy running. Anyone have any ideas what to try next?
Post #562950 10th Sep 2016 5:23pm
Lou Sparts
Check the red plug going to the ecu under the drivers seat for oil, if oil is present you will need to replace the injector harness. 2005 Td5 90 XS
Steve
Post #562953 10th Sep 2016 5:35pm
oakworthboy
Already checked, its clean and dry
Post #562954 10th Sep 2016 5:41pm
Lou Sparts
Not that then ! 2005 Td5 90 XS
Steve
Post #562956 10th Sep 2016 5:46pm
oakworthboy
Its driving me mad trying to find the problem, I'm thinking turbo.
Post #562957 10th Sep 2016 5:50pm
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
Check the Waste gate is not seized.....sounds like your issue Working towards Carry on camping!
Post #562967 10th Sep 2016 6:35pm
oakworthboy
I can move the actuator rod and have oiled it
Post #562970 10th Sep 2016 6:41pm
JWL
Might it be a problem with the throttle potentiometer?
Post #562993 10th Sep 2016 7:43pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Saves collecting points on ya lisence though Thumbs Up
Post #563032 10th Sep 2016 9:57pm
Super7
United Kingdom 1999 Defender 90 Td5 CSW Rutland Red
My farmer spec TD5 has always hit the rev limiter at just over 70mph - I thought it was a case of TADTS Shocked '99 TD5 Defender 90
'52 Series 1 80"
'99 Caterham 7
Post #563080 11th Sep 2016 7:53am
oakworthboy
It was doing 90 the previous week, on a private road of course!
Post #563087 11th Sep 2016 8:03am
lightning
Looking at the RPM when doing 70mph a Defender should theoretically exceed 100 mph (where legal) without hitting the rev limiter, if it had enough power.
I had an Alive remap but sadly it did not work on my TD5, it produced huge clouds of white smoke. So l am back to standard.
While not fast, we recently drove 1,000 miles up to/around Scotland and never really felt it wanting for power.
Cruising speed seems to be 65-70 mph which is smooth and not too noisy. I wouldn't want to go much faster in a 2005 vintage 110.
Post #563130 11th Sep 2016 12:20pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
when my fuel pump and fpr started dying the 1st thing I noticed was a reduced top speed.
It wouldn't go past 70, then a few weeks later 60 was flat out and then just before it started screaming and died 50 mph and it was dog slow on acceleration
I didn't notice for a while because I usually cruise at 60 but the odd blip past 70 to overtake 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #563214 11th Sep 2016 8:34pm
oakworthboy
They were both replaced with genuine Land Rover parts at beginning of year
Post #563218 11th Sep 2016 8:53pm
toastkid
You say you disconnected the MAF and it was just the same.
Do you really mean it was the same in all ways or just the 70mph issue? If it was just the same completely then your MAF is chuffed.
Post #563291 12th Sep 2016 8:06am
