![]() | Home > Puma (Tdci) > Wobbly steering - just can't get it sorted out |
sidler Member Since: 18 Apr 2013 Location: Netherlands Posts: 12 ![]() ![]() ![]() |
Hi all,
After my trip to Iceland i experienced that the steering of my Defender really did not like that holiday as much as I did ![]() It has the 'wobble of death' at speed and when doing +/- 30km in a traffic jam I feel the car wobbling slowly from left to right. Also, it feels very unsecure at speed especially when towing a trailer. I tried to fix a lot of things: - New bearing on one of the wheels, it got loose because the locking nut apparently never had been locked - Replaced the panhard rod bushes - Got new wheels and tyres (i didn't buy them to fix my problem but at least it locks out one of the possible causes) - Checked, replaced and adjusted the swivel bearings on the swivel where the wheel bearing was loose (the swivel was also very loose) - Checked all joints between steering rod etc. the are okay - Replaced the front shock absober bushes What i did notice is that the steering shaft has some play on the UJ's so I'll replace that in a short while. Although I can feel this when steering, it couldn't rectify my car wobbling when going slow on tarmac. What I would like to ask your help for: - Do you know any other possible causes? - Is it possible to adjust the steering box on a Puma 2.4 Defender? It also has a lot more than normal play (with engine running and the wheels straight) Thanks for thinking along! Cheers Paul |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Did you set the preload on swivels? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
steering damper? 2002 90 Td5 Station Wagon
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2050 ![]() ![]() |
Wheels not balanced correctly?
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
I would try wheels balanced first front and back
Swivel preload wobble ive noticed more when braking in the past I also assume there is nothing loose in the system? Mike |
