Home > Puma (Tdci) > 2.4 Puma Engine Surging |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 361 |
First thing you should do is check fuse of brake-light. If thats fine, read
http://www.defender2.net/forum/topic579.html Feedback appreciated |
9th Sep 2016 7:12am |
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 |
Hello Hornet,
Thanks for your reply. I have read your linked thread but can say it's not the same issue. This is a very recently occurring issue and is intermittent (50-60% of the time). Clutch switch replaced yesterday and it's still happening. Mark |
9th Sep 2016 8:37am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17369 |
Any DTCs?
This could be a VCV fault. VCV faults can cause many strange symptoms, usually without DTCs. |
9th Sep 2016 10:21am |
Hi Blackwolf,
Vcv was replaced also and it's still surging - no faults registered. Interestingly it's only occurring in the 2500 to 2800 rev range. M |
9th Sep 2016 10:50am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20341 |
Is your EGR valve working?
9th Sep 2016 11:42am |
yes no issues with EGR
9th Sep 2016 12:38pm |
Eau02467 Member Since: 20 May 2015 Location: Glasgow Posts: 48 |
It sounds like clutch switch but given you have replaced it i would look at other things in same area. Is the wiring to switch intact? Also When was the clutch fluid last replaced? Old fluid may not be holding up to hydraulic pressure and not activating the switch.
9th Sep 2016 7:48pm |
Also another cause can be sticking turbo actuator
9th Sep 2016 7:49pm |
Clutch fluid was changed last month.
Will need to check the turbo actuator - was thinking along those lines and also need to check the turbo modulator harness whilst I'm at it. Thanks M |
9th Sep 2016 9:03pm |
