![]() | Home > Maintenance & Modifications > Wipac Crystal Halogen headlamps and better bulbs - worth it? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20629 ![]() ![]() |
Stacey007 - Stainless headlight bezels do nothing bar prevent corrosion issues which as standard they are prone to rusting out.
Photos: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge (Poor quality photo sadly, sun was a bit bright!) Veetee - Yes, that sounds about right. I'm 99% sure LR are flogging a generic 'Lucas' headlight switch as genuine for a LOT higher price. (Maybe I'm wrong?) Does the switch take current for the headlights only or for sidelights etc too? If just headlights that's fine but if sidelights too mine would be reduced a little by running LEDs. Miker - I have a similar mindset to you as well on those. Only thing that has put me off going for LED headlights is cost. And ice issues, but that is so unlikely and such a small problem / issue its not worth dicussing unless you went to cold countries. |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 ![]() ![]() ![]() |
One of the biggest differences is made by modifying the wiring to the lights, adding in relays to take the power rather than the switch. It resulted in the voltage at the bulb on mine going from 10 volts to 13 volts. Can be bought from Paddocks for under £30, I bought the equipment and did my own
http://www.paddockspares.com/boomslang-per...-loom.html 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
Assume the upgraded headlight loom isn't as important with LED (I have trucklites) as the draw is lower than "normal" bulbs? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
that would depend on how old your switch was when you fitted the I suppose. Simple test is measure the voltage at the back of the headlight compared to back of the alternator or battery, wherever you would choose to take the power feed from. 2015 RRS Autobiography SDV6
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 719 ![]() ![]() ![]() |
I was under the impression that although the led bulbs may be e marked, they are illegal to fit into a light housing that was designed for filament bulbs.
Before my I changed to led, I had osram night breakers, wipac crystals and an upgraded loom. The difference to standard was unbelievable and makes you wonder why it wasn't done as standard. |
Operating voltage with alternator charging should be around 14.2v direct at the battery.
At the headlights on mine it's 12.1v. However, I think I checked that with ignition on only. However, they do vary in voltage at the lights! |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3803 ![]() ![]() |
Custom90
Thanks for the pics, Given I have the bulbs, the wipac clears seem to be the way forward ![]() Rather do it now while weather not too bad.. |
Lew-M Member Since: 04 Apr 2016 Location: North West Posts: 95 ![]() ![]() ![]() |
Anyone have a link for where to get the stainless bezels from?
Thanks, Lew |
I have the mobile centre ones...
https://www.mobilecentre.co.uk/index.php?m...cts_id=617 Mine are silver tho... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
found the silver ones
https://www.mobilecentre.co.uk/index.php?m...cts_id=616 cheaper too ![]() |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
It's true about the voltage drop through the switch and wiring, this will cause the headlights to be more dim than they should, however a second very good reason for fitting secondary relays (Boomslang Etc.) after some decent bulbs, is to greatly improve the reliability of the light switch itself, it's a very outdated design to have all the power for the lights coming directly through the switch, little wonder that so many people have had theirs melt or simply stop working. That's why I've fitted a Boomslang loom with uprated bulbs and Crystal lamps, one of the most worthwhile mods I've done. ![]() |
I know the issue you mean, direct current through the switch.
![]() My SS bezels came from BoB via eBay, they are all the same where ever they come from. It's worth remembering 4x4 Overlander sell stainless fixings and clips etc too as the bezels don't come with any. My own 90 has stainless bezels but standard fixings which need swapping. That reminds me to do that! Finally what ever you are doing with the lights they'll likely need the beam angle etc adjusting. Especially come MOT time, either get them aligned first or often testers will do in on the MOT anyway. |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Are all the later Defenders wired in the same way?
I have a MY14 - do I need a harness as well? |
