Home > Maintenance & Modifications > Tyre size question |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
Wil a 305 70 16 fit the standard county alloy and will it rub ?
Thanks Pom |
1st Feb 2011 10:38pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
You'll be adding 1" to the radius and about 7" to the radius (about 6-7%) so your speedo will be out by that much.
You can make the width work but not on standard alloys (or steels) - you'll need a greater offset. Also, I assume your standard wheels are 7" so they won't accommodate a 305. You'll need a wider rim. HTH A One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
1st Feb 2011 11:10pm |
Thanks for that. Will be sticking to the 265 75 16 then.
Pom |
1st Feb 2011 11:15pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Pom have a play with this http://www.miata.net/garage/tirecalc.html NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
2nd Feb 2011 10:04am |
thanks thats dead handy for us mortals who didn't take tyre algebra! Pom |
2nd Feb 2011 11:17am |
