Home > In Car Electronics > 2007 Defender 90 - ignition switch wiring diagram |
2 GOS Member Since: 03 Aug 2014 Location: Hertfordshire Posts: 66 |
Hi,
Does anyone have access to an ignition switch wiring diagram for a Puma - 2007? Basically, which colour wire should switched items connected to? Thanks in advance. |
5th Sep 2016 8:16am |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
Click image to enlarge Is this any help? I started with nothing and still have most of it left! |
5th Sep 2016 8:51am |
Wow. Huge thanks but do you have anything more simple?
I need to know what colour cable does what on the back of the switch. Thanks again. |
5th Sep 2016 10:08am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 |
Brown/White - permanent 12V
Orange/White - Accessory (Position I) 12V to fuse box then to radio, lighter socket and heater fan White - Ignition (Position II) 12V out to fuse boxes Red/White - starter relay 1988 90 Td5 NAS soft top 2015 D90 XS SW |
5th Sep 2016 10:14am |
Many thanks Martin. Appreciated.
Sorry to be dense but do you know if it is reasonable to take use White - Ignition (Position II) as switched trigger - i.e DRLs on? Thanks again. |
5th Sep 2016 10:34am |
It would be fine, but it's a very large cable at the switch, so difficult to "tap" into reliably (particularly given the restricted space available).
I would personally use one of the white with green stripe cables (all of these are ignition switched) down near the steering column fuse box. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
5th Sep 2016 1:19pm |
Just the advice I needed. Thank you.
5th Sep 2016 2:07pm |
