Home > Wheels & Tyres > Ifor Williams GD85 - how to put LR wheels on?
rockhound42
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
I have an Ifor Williams GD85, it currently has 4 stud 14inch rims fitted.
Not knowing much about PCD's and other wheel related numbers, does anyone know which hubs I would have to swap too to be able to fit some Land Rover size wheels too the trailer?
I know it can be done as the trailers I've towed while working out in the Peak District many years ago all had LR steel wheels and suitable tyres attached.
Thanks for any help.
Post #560799 2nd Sep 2016 12:32pm
Guessing Your GD85 is a single axle ?
Post #560814 2nd Sep 2016 1:42pm
rockhound42
Yep, should have mentioned that.
Post #560815 2nd Sep 2016 1:43pm
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
Personally I'd call into a local Ifor dealer and talk it through with them to make sure everything goes swimmingly. But, in the meantime:-
I believe the 4 stud axles are on 200 x 50 drums which equates to. KS0825 Hub Kit. To change to a 5 stud pattern you'd need to swap these "Hub Kits" (drum, bearing, etc etc) to the KS0826 which is effectively the same drum / hub kit but with 5 holes instead of 4.
However, back to my first paragraph, go armed with all the info but check with you local Ifor dealer / service centre first in case there are descrepancies in the years etc.
Above all remember - I'm not an expert Thumbs Up Rolling with laughter
Post #560916 2nd Sep 2016 8:11pm
rockhound42
Thanks for that Riccarton. Gives me something to look at in a bit more detail before going to the dealers.
Post #561522 5th Sep 2016 9:54am
Penuwchian
Wales 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I've got a GD85- and would have thought that the LR wheels would be far too big for it? We've had other Ifors running on LR wheels in the past- but they've then 12.50-16 series type wheels I think? Not sure that you'd get the 265-80-16 tyre to fit at all?
As stated above- best bet would be to speak to a dealer- although I guess they may well just tell you it's not practical?
Post #562081 7th Sep 2016 8:28am
muddybaldboy
Wales 1999 Defender 110 Td5 HT Chawton White
6.50 r16 are an option on Gd84 so definitely possible (with bigger mudguards) He who dies with the most toys...wins!
Post #562155 7th Sep 2016 1:35pm
