Home > Puma (Tdci) > Wipers stopped working TD4 - 90
p_jeeeee
Belgium 2007 Defender 90 Puma 2.4 SV 90 Caprice
Recently front wipers suddenly stopped working. I checked the fuse, changed the relay and switch on the steering wheel but without success. Currently my wipers are still pointing to the moon….
Anyone an idea on what it could be and how to sort it out?
It is a Land Rover Defender 90 - TD4 build in 2007
Post #559936 30th Aug 2016 10:53am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Is there power to the wiper motor? it could be a few things; seized wheel boxes, snapped shaft on the motor itself, the motor itself is u/s.
Start with removing the motor and drive cable then manual turn the wheel boxes, if they are OK connect the motor externally and test it for function. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #559939 30th Aug 2016 11:10am
p_jeeeee
how do i get to the motor? do i need to remove the complete dashboard?
Post #559942 30th Aug 2016 11:16am
Mash
Good question, I was thinking of a 300tdi when I wrote that. Not 100% sure on the puma, as I haven't worked on them before. You could try YouTube for a vid showing how, sorry I can't help any further. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #559946 30th Aug 2016 11:27am
dorsetsmith
Post #559949 30th Aug 2016 11:37am
