Home > Puma (Tdci) > Wipers stopped working TD4 - 90
p_jeeeee
Belgium 2007 Defender 90 Puma 2.4 SV 90 Caprice
Recently front wipers suddenly stopped working. I checked the fuse, changed the relay and switch on the steering wheel but without success. Currently my wipers are still pointing to the moon�.
Anyone an idea on what it could be and how to sort it out?
It is a Land Rover Defender 90 - TD4 build in 2007
Post #559936 30th Aug 2016 11:53am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Is there power to the wiper motor? it could be a few things; seized wheel boxes, snapped shaft on the motor itself, the motor itself is u/s.
Start with removing the motor and drive cable then manual turn the wheel boxes, if they are OK connect the motor externally and test it for function. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #559939 30th Aug 2016 12:10pm
p_jeeeee
how do i get to the motor? do i need to remove the complete dashboard?
Post #559942 30th Aug 2016 12:16pm
Mash
Good question, I was thinking of a 300tdi when I wrote that. Not 100% sure on the puma, as I haven't worked on them before. You could try YouTube for a vid showing how, sorry I can't help any further. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #559946 30th Aug 2016 12:27pm
dorsetsmith
Post #559949 30th Aug 2016 12:37pm
