Home > Maintenance & Modifications > Steering damper nut/bolt
Screbble
Just being a big lazy really (well it is Sunday)......
Does anyone know the dimensions and/or part number of the bolt (or set screw to be more precise?) that fixes the steering damper to the chassis?
About to fit a new OEM damper first and then finally get round to fitting the steering guard. They've been in the garage on the 'to do' list for some time, and I've got a bit of free time next week.
Thanks in advance,
Will[/i]
Post #559449 28th Aug 2016 7:55am
Martin
Site Admin
The damper to chassis is a threaded pin on the damper and bushes and two nuts (1 a lock nut) to fix to chassis
The lock nuts are AFU4214 or QYH500120
The other end, damper to drag link, is a bolt (screw) and nut.
BH110121L aka M10 x 60mm
WA110061L M10 washer
NY110047L M10 nyloc nut
A new boxed damper should come with the chassis end bushes and nuts but not usually the drag link bolt.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #559502 28th Aug 2016 10:29am
Martin
Site Admin
ps: those photos are ones I found of a LHD Defender a RHD is a mirror image Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #559503 28th Aug 2016 10:31am
Screbble
That's spot on Martin. Thank you very much Thumbs Up
Yes all of the washers, bushes and nuts for the 'stud' end (the chassis end) are in the box, however the drag link bolt/screw and nut aren't - as you suggested.
Thanks for the info/spec for the latter Martin - very much appreciated. Thumbs Up Thumbs Up Thumbs Up
It's a good job you told me it was a mirror image as I'd zoomed in on the thread and was going to buy a left hand thread! Rolling with laughter
Cheers,
Will
Post #559505 28th Aug 2016 10:47am
