Home > Td5 > Transmission oil |
Loz2286 Member Since: 31 Aug 2015 Location: High Wycombe Posts: 121 |
Having trouble finding suitable transmission oils for my 1999 110. The usual suspects shrug their shoulderswhen I mention MTF.
Any idea of stockists? 1999 Td5 110 CSW 1961 Series 2 88 LPG |
15th Aug 2016 12:47am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
http://www.smithandallan.com/products/tran...-gear-oil/
Enough for two services of an R380 box Steve 02' 110 TD5 Double Cab Rebuild Thread |
15th Aug 2016 9:13am |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
LR do it...genuine article though may cast approx. £50 for 5 litres but that's enough for two changes so it becomes £25 per refil
16th Aug 2016 5:46pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Personally I use the Fuchs alternative will drag out the details of it tomorrow. Never been a fan of MTF94. I find it ruins the shifts and if you sample it the wear rates are terrible. Worse than running ATF ironically
17th Aug 2016 9:07pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
The genuine oil is available in litre bottles. My local independent sourced it for me 2002 110 td5
18th Aug 2016 8:27am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
As you're in high Wycombe, speak to dingocroft. I'm pretty certain they sourced it for me last time I needed it. |
18th Aug 2016 10:23am |
Of course! Duh! 1999 Td5 110 CSW
18th Aug 2016 2:44pm |
Given that LR are so adamant that it should only be MTF94, how do you know that the fuchs stuff is definitely good for the box? Genuine question, I don't like the shifting on my (refurb) r380 at the moment. |
26th Aug 2016 12:22am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
FWIW - this is the Service Advisory:
Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
26th Aug 2016 7:08am |
Things have moved on a little since 1998
I sample oils as we have an oil lab in work so makes sense to me. The wear rates with MTF are not the best by any means. This is just my findings. I'm not saying don't use it, just that there are better lubricants for similar and sometimes less money. Fuchs Titan sintofluid 75 80 is just my preference. Just my 2p worth... |
26th Aug 2016 12:35pm |
Well, glad I asked! Oil lab is convincing enough for me. When I change my gearbox next I'll get some
26th Aug 2016 12:39pm |
I'll find a report and post it up when I get 5
26th Aug 2016 1:38pm |
Now I'm confused. ... 1999 Td5 110 CSW
26th Aug 2016 10:36pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2081 |
I too am interested in hearing more Fatboy Slim I've been using the LR MTF94 for some time with no issues, other than cost and occasional availability, however I am keen to embrace change as long as it is for the better. Fuchs products are excellent, and as long as the spec is spot on then I can't see why it shouldn't be a bonafide alternative. Looking forward to hearing more |
27th Aug 2016 10:27am |
