Home > Td5 > Transmission oil
Loz2286
Transmission oil
Having trouble finding suitable transmission oils for my 1999 110. The usual suspects shrug their shoulderswhen I mention MTF.
Any idea of stockists? 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #556104 15th Aug 2016 12:47am
excossack
Ebay for a 5l tub of MTF94, Duckworths (forum sponsor), Opie oils. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #556128 15th Aug 2016 7:49am
rallysteve
http://www.smithandallan.com/products/tran...-gear-oil/
Enough for two services of an R380 box
Post #556143 15th Aug 2016 9:13am
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
LR do it...genuine article though may cast approx. £50 for 5 litres but that's enough for two changes so it becomes £25 per refil Shocked
Post #556506 16th Aug 2016 5:46pm
Fatboy Slim
Wales
Personally I use the Fuchs alternative will drag out the details of it tomorrow. Never been a fan of MTF94. I find it ruins the shifts and if you sample it the wear rates are terrible. Worse than running ATF ironically
Post #556804 17th Aug 2016 9:07pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
The genuine oil is available in litre bottles. My local independent sourced it for me 2002 110 td5
Post #556886 18th Aug 2016 8:27am
miker
Re: Transmission oil
As you're in high Wycombe, speak to dingocroft. I'm pretty certain they sourced it for me last time I needed it.
Post #556910 18th Aug 2016 10:23am
Loz2286
Of course! Duh! 1999 Td5 110 CSW
Post #556984 18th Aug 2016 2:44pm
miker
Given that LR are so adamant that it should only be MTF94, how do you know that the fuchs stuff is definitely good for the box? Genuine question, I don't like the shifting on my (refurb) r380 at the moment.
Post #559009 26th Aug 2016 12:22am
MartinK
FWIW - this is the Service Advisory:
Quote:
Defender Date: 25.11.98
Freelander
AFFECTED RANGE:
All R380 manual gearbox derivatives - refer to text for specific change points
All Freelander
PROBLEM:
GEARBOX OIL - CHANGE TO SPECIFICATION
CAUSE:
At the following VINs, the original oil fill specification for the R380 gearbox was changed to Texaco MTF94 high performance oil:
Range Rover - WA 384300
Discovery - WA 752315
Defender - WA 131138
New Discovery - All vehicles
The Freelander PG1 gearbox has used the new oil since introduction of the model.
ACTION:
MTF94 will be recognised by its orange/honey colour as opposed to the red
Dexron II oil previously used, and is now available from Land Rover Parts.
It is now the only oil which should be used for topping up and complete fill on R380/PG1 gearbox applications.
The new oil is compatible with the old and to enable earlier vehicles to benefit from
its introduction, should be used retrospectively on vehicles prior to the above VINs
for all top up and refill requirements.
Refer to PARTS INFORMATIONoverleaf for details.
Until further notice, current Service Schedule gearbox oil change periods are retained and must be adhered to.
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #559040 26th Aug 2016 7:08am
Fatboy Slim
Wales
Things have moved on a little since 1998 Very Happy
I sample oils as we have an oil lab in work so makes sense to me. The wear rates with MTF are not the best by any means. This is just my findings. I'm not saying don't use it, just that there are better lubricants for similar and sometimes less money. Fuchs Titan sintofluid 75 80 is just my preference.
Just my 2p worth...
Post #559092 26th Aug 2016 12:35pm
miker
Well, glad I asked! Oil lab is convincing enough for me. When I change my gearbox next I'll get some
Post #559094 26th Aug 2016 12:39pm
Fatboy Slim
Wales
Thumbs Up I'll find a report and post it up when I get 5
Post #559106 26th Aug 2016 1:38pm
Loz2286
Now I'm confused. ... 1999 Td5 110 CSW
Post #559254 26th Aug 2016 10:36pm
Screbble
I too am interested in hearing more Fatboy Slim Thumbs Up
I've been using the LR MTF94 for some time with no issues, other than cost and occasional availability, however I am keen to embrace change as long as it is for the better.
Fuchs products are excellent, and as long as the spec is spot on then I can't see why it shouldn't be a bonafide alternative.
Looking forward to hearing more Thumbs Up
Post #559307 27th Aug 2016 10:27am
