Home > Technical > Let me guess....they all do that - its normal |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6312 |
not too much......?
I can honestly say the 'imaginary' problems are far more entertaining. As BM has mentioned the motor has some kind of thermal safety device - can anyone confirm what this is, how it works and whether it's a quick fix? the other thing - is there anymore involve than just the stalk, motor and park switch mounted on the motor ie no relay anywhere? |
25th Aug 2016 12:23pm |
Thank you BW.
if rack / box are U.S any idea if I might get one tomorrow (some thing to fit while I'm away the weekend?) |
25th Aug 2016 1:27pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17491 |
They are usually stock items at main dealers since (a) they fail a lot and (b) I think they are essentially unchanged since the introduction of the Series IIA in 1968.
ISTR when I replaced mine that the drive rack and two wheelboxes came to around £30 in total. |
25th Aug 2016 3:09pm |
Thank you. Wi hopefully diagnose this even and get parts to fit tomorrow while on hols the weekend
25th Aug 2016 5:05pm |
I managed to fix it last night.....jobs a goodun!
All good to go t weekend now |
26th Aug 2016 4:40am |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
^^^...and the problem was..?
Cheers Simon |
26th Aug 2016 6:59am |
I only did the first phase of the fix - took it to IRB
Ian opened up for me and did some checks and ultimately it turned out that the shafts were seize where they penetrate the bulkhead. Simples. So will be using plenty of acf50 going forward. Something to consider guys. Ian. If you're reading this. Really appreciate your help on this as weekend with caravan could have been cancelled. |
26th Aug 2016 7:05am |
