Home > Technical > Speedo lights |
Scott_Landy Member Since: 24 Aug 2015 Location: Cheshire Posts: 85 |
It's on a '93 200 Tdi if that helps at all...
22nd Aug 2016 6:44am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4709 |
From the handbook
Click image to enlarge Click image to enlarge 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
23rd Aug 2016 4:11pm |
Thanks spud. Bulb swap is done ok now.
Guess hand books don't cover "we used chap plastic parts so when the white bulb holder snaps off and leaves the green lends inside the speedo, well, you're on your own with the rattling from here to eternity...." |
23rd Aug 2016 4:33pm |
If you undo the speedo cable and withdraw the bulbs and connections then withdraw the instrument panel you can hold it upside down and give it a shake. Any luck the offending bits will fall out! 1982 88" 2.25 diesel
23rd Aug 2016 7:32pm |
Super,glue! Hopefully that will solve the problem! Guess I stick with Greek lights but from an updated LED bulb.
Thanks Spud! |
23rd Aug 2016 9:23pm |
23rd Aug 2016 9:36pm |
