Home > Maintenance & Modifications > Sound deadening
cutts
2008 Defender 110 Puma 2.2 HT Alveston Red
Sound deadening
Has anyone fitted any sound deading under the seat box? Does it actually make a difference
Post #558120 22nd Aug 2016 9:53pm
I have, just the base only inside.
Definitely every little helps!
If you do the whole outside of the seatbox then just the base of the inner seatbox needs to be done.
It is, a fair size single pael that would resonate given the chance.
Post #558139 22nd Aug 2016 10:23pm
cutts
Thanks
Does the rubber seat box cov is still fit it though
Post #558174 23rd Aug 2016 2:39am
Stacey007
Yes and Yes
I think in mine almost the biggest difference at the front..
I rushed a little so need to re visit, take the battery out and do under / around as I could not get my hand in properly
Maybe overkill I'm not sure but I think it works so I'm happy with results.
Post #558217 23rd Aug 2016 8:55am
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Hi Stacey007,
I am curious, did you seal the "holes" in the battery box or left them open?
Steve
Post #558220 23rd Aug 2016 9:03am
Stacey007
Hello
Any holes, I left as I thought they were breather holes for any nasties in their?
Post #558227 23rd Aug 2016 9:30am
simond
I fitted the Noisekiller kit to my 2010 Puma SW last year, and it made a significant difference, much quieter...... one of those improvements you appreciate every day. It took a few hours to fit, theres around 60 precut pieces, some foil wrapped, some a composite layer material, worth every penny.
PS: I wouldn't be using a foil backed material in the battery compartment. Simon D
Post #568211 2nd Oct 2016 12:39pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
I put 6mm closed foam under the seat box lids, and some on the sides which has stopped a lot of noise bouncing around. Well worth it.
Post #568221 2nd Oct 2016 2:18pm
