![]() | Home > Maintenance & Modifications > Sound deadening |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20761 ![]() ![]() |
I have, just the base only inside.
Definitely every little helps! If you do the whole outside of the seatbox then just the base of the inner seatbox needs to be done. It is, a fair size single pael that would resonate given the chance. |
cutts Member Since: 06 May 2016 Location: UK Posts: 36 ![]() ![]() |
Thanks
Does the rubber seat box cov is still fit it though |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3820 ![]() ![]() |
Yes and Yes
I think in mine almost the biggest difference at the front.. ![]() Click image to enlarge I rushed a little so need to re visit, take the battery out and do under / around as I could not get my hand in properly ![]() Click image to enlarge ![]() Click image to enlarge Maybe overkill I'm not sure but I think it works so I'm happy with results. Cheers |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
Hi Stacey007,
I am curious, did you seal the "holes" in the battery box or left them open? Steve |
Hello
Any holes, I left as I thought they were breather holes for any nasties in their? |
simond Member Since: 15 Feb 2008 Location: Kent Posts: 26 ![]() ![]() |
I fitted the Noisekiller kit to my 2010 Puma SW last year, and it made a significant difference, much quieter...... one of those improvements you appreciate every day. It took a few hours to fit, theres around 60 precut pieces, some foil wrapped, some a composite layer material, worth every penny.
PS: I wouldn't be using a foil backed material in the battery compartment. Simon D |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
I put 6mm closed foam under the seat box lids, and some on the sides which has stopped a lot of noise bouncing around. Well worth it.
