Home > Technical > JW speaker flicker on sidelights only |
check the voltage of the flickering one vs the good one. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
21st Aug 2016 10:29am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4786 |
I'm guessing your vehicle has dim dip? If so that will be providing reduced voltage to the lamps with the master switch in the side lights position, causing them to flicker.
To stop it happening you need to disable dim dip by unplugging the dim dip resistor. It is under the bonnet near the brake master cylinder i believe. Hope that helps 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
21st Aug 2016 2:27pm |
HossBog Member Since: 22 Jul 2015 Location: Glos Posts: 131 |
Brilliant, thx, will give that a try! 2002MY Defender 90 H/T
22nd Aug 2016 6:35pm |
