![]() | Home > Technical > Headlight motor buzzing |
1. check head lamp are moving to giver at level setting on the switch
2. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge you can adjust headlight motor to check if they free to move |
TechnoTurkey Member Since: 25 Jul 2016 Location: Worcestershire Posts: 88 ![]() ![]() |
Thanks, I'll take a look as soon as I can!
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2326 ![]() ![]() ![]() |
And check that the headlights haven't been screw down so tight they can't move when the motor is trying to adjust them.
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3665 ![]() ![]() ![]() |
so my headlights have decided to stop levelling , neither moves, this has happened before but fixed itself before I could investigate.
Symptom's are headlights don't move when switch is operated Checked the wiring diagram and it suggest feed is from fuse 20 and this also feeds instrument lights which are fine therefore I am suspecting the swich, an earth or dodgy plug/wiring any recommendations where to start? DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
Always begin with the Earths, then power to the switch, then the wiring loom and finally 12v to the motors to check those.
It is a simple circuit, but I can see there are a pair of connectors that might be faulty. These will be in the wing extension looms. https://www.lrworkshop.com/wiring-diagram/...-levelling |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
The rotary switch does play up, take it out, pop the back off and the contacts can be cleaned and re-lubricated.
Geobloke / Martin
thanks for the guidance sounds like a job for next weekend DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
thanks Gents, purchased a new switch from site sponsor, fitted today and all working again, tried to dissemble the old switch and broke it so good job I brought a new one DEFENDER 90 TDCI XS,
matchap801 Member Since: 05 Aug 2021 Location: Somerset Posts: 120 ![]() ![]() ![]() |
I stripped my switch apart. Re-soldered all the connections. From memory there was a back plate that wasn't connecting properly to the power pins - removed old solder, cleaned, re-soldered. All good.
I also removed the dull green led and added wo new white let's. Much better. 2009 Defender 90 CSW 2.4 TDCI. Ex Army Mechanic still living the dream. |
