Home > Technical > Headlight motor buzzing
TechnoTurkey
2005 Defender 110 Td5 CSW Zambezi Silver
Hi all,
Any tips for a headlight where the motor is buzzing regardless of the level setting on the switch? It's louder on the highest setting but still noticeable on the others.
It's happening today for the first time, it is probably no coincidence that I changed the setting for the first time last night! This may be the first time they were ever used so perhaps they are just stiff/stuck??
Post #557229 19th Aug 2016 1:29pm
dorsetsmith
1. check head lamp are moving to giver at level setting on the switch
2.
you can adjust headlight motor to check if they free to move
Post #557237 19th Aug 2016 2:11pm
TechnoTurkey
Thanks, I'll take a look as soon as I can!
Post #557242 19th Aug 2016 2:36pm
Mo Murphy
And check that the headlights haven't been screw down so tight they can't move when the motor is trying to adjust them.
50 Shades of Pennine Grey
Post #557268 19th Aug 2016 5:11pm
LR90XS2011
so my headlights have decided to stop levelling , neither moves, this has happened before but fixed itself before I could investigate.
Symptom's are headlights don't move when switch is operated
Checked the wiring diagram and it suggest feed is from fuse 20 and this also feeds instrument lights which are fine
therefore I am suspecting the swich, an earth or dodgy plug/wiring
any recommendations where to start? DEFENDER 90 TDCI XS,
Post #983816 27th Feb 2023 7:54am
geobloke
Always begin with the Earths, then power to the switch, then the wiring loom and finally 12v to the motors to check those.
It is a simple circuit, but I can see there are a pair of connectors that might be faulty. These will be in the wing extension looms.
https://www.lrworkshop.com/wiring-diagram/...-levelling
Post #983833 27th Feb 2023 10:21am
Martin
Site Admin
The rotary switch does play up, take it out, pop the back off and the contacts can be cleaned and re-lubricated.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #983849 27th Feb 2023 12:04pm
LR90XS2011
Geobloke / Martin
thanks for the guidance sounds like a job for next weekend DEFENDER 90 TDCI XS,
Post #983882 27th Feb 2023 4:22pm
LR90XS2011
thanks Gents, purchased a new switch from site sponsor, fitted today and all working again, tried to dissemble the old switch and broke it so good job I brought a new one DEFENDER 90 TDCI XS,
Post #984536 5th Mar 2023 8:41pm
geobloke
Thumbs Up Well done.
Post #984537 5th Mar 2023 8:44pm
matchap801
United Kingdom 2009 Defender 90 Puma 2.4 CSW Zermatt Silver
I stripped my switch apart. Re-soldered all the connections. From memory there was a back plate that wasn't connecting properly to the power pins - removed old solder, cleaned, re-soldered. All good.
I also removed the dull green led and added wo new white let's. Much better. 2009 Defender 90 CSW 2.4 TDCI.
Ex Army Mechanic still living the dream.
Post #984580 6th Mar 2023 1:00pm
