Home > Technical > LT85 stuck in reverse |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6103 |
Whip the top plate off of the gear selector (the whole gearstick will come off)
The LT77's used to suffer from the grub screw working loose on the selector shaft meaning you lost all gears. "simply" move it back to the correct position, apply some locktite to the grub screw and do it up tight. |
14th Aug 2016 6:35pm |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 942 |
I don't think I can get it off because the transmission tunnel is very close to the front of the gear stick? I'll have a look tomorrow anyway, she isn't going anywhere anytime soon so I may as well rip the transmission tunnel off. Would this screw also result in it being stuck in reverse? 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold 1985 Land Rover 110 ex mod project Tithonus ~ Sold |
14th Aug 2016 9:14pm |
Yes, if the box was in reverse when the grub screw slipped off position.
15th Aug 2016 6:33am |
Okay, do I have to take the whole top off or can I just remove the small plate the gearstick goes through? Will attempt it this afternoon anyway as I really can't afford to go to a garage about it! 1999 Land Rover Defender 110 td5 station wagon
15th Aug 2016 10:25am |
