Home > Maintenance & Modifications > Fitting new wing mirror covers, any tips?
JOW240725
Just bought some colour coded wing mirror covers and I'm after fitting instructions, tips, please?
Thank you James
Instagram @suffolk_rovers
Post #555869 14th Aug 2016 8:40am
grafty99
I would have said to do it in the sun as the rubber is more supple. Having never fitted a pair I don't know what else to suggest Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #555886 14th Aug 2016 9:55am
Wheel
Hi,
I bought some of these, £20 ish I think for what looks like they're made from margarine tub plastic but once painted Corris + fitted they do finish the mirrors off a treat.
I had the arms gloss blacked too so my mirrors were in bits but you have to build the mirror up first rather than put the cap on + then assemble.
Ask me how I know !!!!!
Anyway, I put the rubber in the oven (not overly hot or for too long) to make it easier but if we have a very hot day you may get the same results.
I did have an "Oh F*@k" moment when I opened the oven door as they looked like they'd expanded massively and were round but they were ok and went on easily, and I had to do one twice due to putting one cap on first.
Hope that helps
Mark
Post #555894 14th Aug 2016 10:20am
Put rubber seals in a jug of boiling water
Post #555919 14th Aug 2016 12:25pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
A bit of fairy liquid alway make rubber more pliable (other makes are available) Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #555922 14th Aug 2016 12:33pm
alastaid
I fitted mine, sat in the sun, got them warm, start on the longest side in the middle and prise it off with your thumbs, and work towards a corner, once you have one corner off its easy. I found putting them back on easier than taking off, get two opposite corners on making sure the rubber has parted open, then slowly work to the other corners. I managed it all with my hands, didn't use any tools.
Alastair
Post #555928 14th Aug 2016 1:03pm
I'd second go beyond and jeffersj.
Be careful of dropping the glass, with wet hands it can be like trying to hold a wet fish!
To get the rubber off, warm it with a hair dryer use either your hands if you can.
If it's really stiff. Shocked Shocked
Something like a blunt plastic trim too should free it.
Fitting the new covers make sure you use only your hands to avoid damage.
I have them on mine, it is indeed easier to re-fit than remove.
If it suits you can just take the mirror and arm off, might be safer to do it on a table or similar instead.
Post #555934 14th Aug 2016 1:57pm
JOW240725
Many thanks guys, very useful as always. I'll give it a bash! James
Post #556450 16th Aug 2016 3:00pm
Orangesofa
United Kingdom 2013 Defender 90 Puma 2.2 SW Keswick Green
I fitted mine on a warm sunny day and only managed the one before my finger tips gave up and said no more. I had to do the second one after my fingers had recovered.
Lots of poking and prodding but got there in the end and very pleased with the result. Phil
Post #556997 18th Aug 2016 4:45pm
JOW240725
Well it was a doodle! Removed the mirrors and sat in just off the boil water for a few minutes then seal easily removed and replaced.
My first purely cosmetic mod, but I'm really pleased with them.
Thanks for your help again Thumbs Up James
Post #557980 22nd Aug 2016 12:07pm
Stacey007
Looks great Smile
I'm tempted but on a black car would you notice them....
Post #557981 22nd Aug 2016 12:08pm
