Home > Td5 > Horn blows when activating alarm |
The horn blows to tell you a door or bonnet isn't closed properly so one of the pin switches on any of the doors or bonnet may be corroded or unplugged and not registering being closed Ray
27th Jul 2016 4:50pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 943 |
Yup agree, check all your door switches and bonnet switch. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
27th Jul 2016 8:08pm |
Wism Member Since: 27 Jun 2016 Location: Surrey, UK Posts: 21 |
Many thanks,
Will look at the bonnet switch |
27th Jul 2016 8:19pm |
Leaky 110 Member Since: 11 Jul 2016 Location: Glasgow Posts: 62 |
Yep, a mislock. I've got the exact same issue with my puma, I've already checked all of the door switches and bonnet switch with no joy. Very frustrating, as the alarm has a mind of its own.
When I bought the car the previous owner had bypassed the horn rather than sort the fault! I'm guessing it might be the Lucas 10as alarm module, as the interior lights go haywire at the same time. If all else fails, a quick diagnostic can show the alarm event history. From reading other threads about this, dirty switch contacts can be a really common culprit. Let us know how you get on! |
27th Jul 2016 8:34pm |
I'm not sure what I have done but it all appears to be working fine again. I just fiddled around with the door lock and fingers crossed the door closes fine and the alarm works fine. Thanks all
10th Aug 2016 9:35pm |
I had some intermittent issues with mine also, took the switches out and gave em a good clean and made sure the seals were sitting right, no problems for loooong time since.
They're pretty cheap as spares too, as a matter of fact I never got round to installing new ones ... Solved the bowel problem, working on the consonants... |
11th Aug 2016 12:53am |
TechnoTurkey Member Since: 25 Jul 2016 Location: Worcestershire Posts: 88 |
Mine did this after I adjusted the passenger door so it shut tighter, I slackened it off a bit and then it was fine again.
11th Aug 2016 11:42am |
Ayrshirelandy Member Since: 28 Mar 2015 Location: Ayrshire Posts: 140 |
All too familiar. I had it with my Disco and it was the bonnet switch and the Puma does it if the door/bonnet not closed properly. It can seem annoying, but a good reminder that the door / bonnet isn't closed properly! 2015 Defender 110 XS Utility Santorini Black, sawtooth alloys, steps and so much more...........
11th Aug 2016 12:39pm |
Nuke the car from orbit, it's the only way to be sure.
(Still haven't isolated the fault, 2 months after it started) |
11th Aug 2016 12:42pm |
