Home > Maintenance & Modifications > Dynamat installation
TVM
United Arab Emirates
All
Need advice on installing Dynamat extreme to the hood.
- Do you cut the sheet to fit/paste into the spaces where there is no double layer in the hood
- Do you then put an overall cover using Dynamat Hood liner to make it look neater? Is Hood liner required?
- Any pictures would be helpful?
Cheers TVM
Post #554922 10th Aug 2016 6:26am
Have a look on the CSK Land Rovers site, Chris used to have lots of good photos on there.
What you've said sounds right to me, I decided against fitting any under there myself though.
I'm sure you are already savvy enough to ow to wear gloves when fitting, it has edges like razor blades when cutting abd fitting in.
Thumbs Up
Post #554950 10th Aug 2016 9:25am
MartinK
This is the thread you need (prob what Steve refers):
http://www.defender2.net/forum/topic19837.html?highlight=dynamat
Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #554964 10th Aug 2016 10:15am
Yep, some good ones there. Thumbs Up
Post #555001 10th Aug 2016 12:05pm
TVM
Thanks Guys
Will go through the info
cheers
TVM
Post #555007 10th Aug 2016 12:15pm
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
Had mine lined with a 19mm hood liner and it's certainly helped cut down on engine noise. I can't say how it was fitted though as I didn't do it.
Post #555010 10th Aug 2016 12:17pm
TVM
Thanks Riverboy
That's the picture I was after. Do you have Dynamat extreme beneath the Hoodliner?
Steve/Martin
Thanks for the thread and quite useful info. The thread has the complete picture of installation. The only one missing is relating to hood!!
I think I will do the Dynamat extreme first to the areas that can be fixed under the hood and then do a hoodliner
TVM
Post #555214 11th Aug 2016 6:07am
Riverboy
I'm not sure to be honest. The guys that did it did the whole car and did an amazing job so I suspect they did. In the main cabin they added new carpet trim to exposed areas and I wasn't expecting that. If you are doing it yourself then yes I would add as much as you can. Thumbs Up Given your location, you should see a big improvement in heat insulation if you are doing the entire car. It's made a massive difference to mine.
Post #555220 11th Aug 2016 6:35am
MartinK
Argh... lol - "Hood" = bonnet Laughing
I thought "Hood" = roof lol Rolling with laughter Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #555339 11th Aug 2016 2:12pm
TVM
No worries Martin
Managed to get the Dynamat extreme fixed to hood in patches followed by Hoodliner. Definitely lot better. Also managed to fix some to the foot well and the middle row floor.
Cheers TVM
Post #555870 14th Aug 2016 7:43am
