Home > Puma (Tdci) > MY GAP IID Tool won't write stuff to my Defender. |
I've been trying to change some settings in my Defender's computer and it keeps failing.
It will read settings quite happily but crashes every time I try and write something. How do I know whether the problem is with the Defender or the tool? Do Defender computers get issues which mean I wouldn't be able to write to it? Edit: ECU history, it's had Alive disable the EGR valve (and they didn't complain) and Remote Key program a new key to it (which worked fine). I've never been able to write anything with the GAP tool. |
8th Aug 2016 11:47am |
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 244 |
What are you trying to write ? IOS or Android ?
Glen "Rafiki" 2007 110 STW - Rolling rebuild. |
8th Aug 2016 3:29pm |
Anything!
It's saying that the injector learning hasn't been done so I started off with that, but I can't even adjust things like the speed limiter or how the interior lights function. Android. If it's likely to be the tool at fault then I'll contact their support. If it's likely to be the Defender at fault then I've no idea what I'd do to fix it! |
8th Aug 2016 6:37pm |
I cant recall exactly what it said and when but that message rings a bell.
In my case it was because the engine was cooling during the processes. It had to be above some value (that I forget, but it is in the manual if I recall) for the complete procedure. Once I took it for a good blat and stored enough heat in the whole engine block and not just the area the heat sensor that the tool determines that it's ok to start because it's 'warm enough' it was good to go. Solved the bowel problem, working on the consonants... |
8th Aug 2016 10:29pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Drop GAP support an email, the service is very good. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
9th Aug 2016 2:42pm |
PatGAPInnov Site Sponsor Member Since: 19 Jan 2015 Location: Montreal Posts: 45 |
Mail on it's way http://www.gap-diagnostic.com/
9th Aug 2016 4:43pm |
Credit where it's due, an email came before I'd sent one
9th Aug 2016 9:01pm |
What was the issue? Solved the bowel problem, working on the consonants...
9th Aug 2016 9:45pm |
