Home > Maintenance & Modifications > Hard Top Sides |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 615 |
Assuming your truck is a 90 (from your profile) is it possible the panel which does not fit has come from a 110?
I believe that 90 and 110 hard top sides are different. |
4th Aug 2016 11:34am |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
110 (88") are shorter so that wouldn't add up
4th Aug 2016 11:39am |
L90DNY Member Since: 09 Feb 2016 Location: Somerset Posts: 117 |
It is definitely from a 90, I removed it myself at a local breakers. It fits fine, but it is in about an inch from the edge of the cappings on both the side and the back, where as the other side is flush.
4th Aug 2016 12:28pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2245 |
There are 2 types of hard top side for the 90. The earlier ones have an external vertical rib on the front edge and a horizontal anti drum bar across the skin on the inside.
The later sides don't have the front rib and the anti drum bar is vertical. Dimensionally they are the same with the exception of the protrusion of the front vertical rib. When fitting replacement sides, I've always found it easiest to loosely bolt the sides to the tub and the roof and make sure that it all moves within the range I need, investigating and addressing any lack of adjustment before starting to tighten bolts. A common one is the internal bracket at the bottom of the side about half way along. These need slackening off to allow the panel in or outboard and tightened once bottom of the side is located correctly and the corner bolts are tight. Once the bottom is right you can centre the roof up and tighten those bolts. HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
4th Aug 2016 12:52pm |
Ok thanks for the info, this has a vertical bar on the inside, which must mean it should fit flush, if properly adjusted ?
4th Aug 2016 12:58pm |
Remember, it's a Land Rover 😉 The Land Rover 90 - Many are called, few are chosen.
4th Aug 2016 2:23pm |
As far as I'm aware the panels were put in place at the factory and then the holes drilled by a human to bolt the sides up (no robots that get the holes in the same place every time) so the holes could have been drilled in different places. Ray
4th Aug 2016 2:42pm |
I think that is the case, under further investigation today, I think with some fettling it will line up enough.
4th Aug 2016 10:06pm |
