Home > Puma (Tdci) > Any lifted Pumas on here |
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 |
has anyone on here jacked up there puma sucsessfully yet
2nd Dec 2008 9:52pm |
Verdone Member Since: 30 Apr 2008 Location: Gent Posts: 67 |
Me and ive done i dont know maybe 10.000 km's on it and havent noticed anything wrong with it
Verdone |
2nd Dec 2008 10:34pm |
how much of a lift are these
3rd Dec 2008 8:46am |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
They are a medium weight spring and lift it about 40 to 50 mm
3rd Dec 2008 10:54am |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
I can't remember who it was but somenone did suggest that you could use the landrover HD springs which give you about an inch lift. Which I think is a cracking idea as long as it does not make the ride to hard.
3rd Dec 2008 11:25am |
Landy nut Member Since: 22 Dec 2007 Location: In hiding Posts: 154 |
The LR HD spring idea was probably me. I have done that and it works really well. You get a nice firm ride, great towing capacity, excellent control of the car and less body roll. The only thing I would say is that you might want to change the shocks to get the most of the car, for which I would recommend De Carbon as a general use one. I had them on my old off roading toy and they give a lovely ride quality.
I have a 110 double cab, so the rear sits high anyway with the XHD springs on which give you the 1 ton carrying capacity, so I did the fronts too as I have an ARB bumper fitted and they are heavy as heck. The front is now the same height as the rear and the ride and general drive is much better. The really nice thing is that is will not void any warranty and will also not mean a change to your insurance either. They are nicely priced too. I think with my discount I got the pair for £65, so you should be looking at less than £150 for the set. Landy nut |
3rd Dec 2008 12:33pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2415 |
Hi Sonic3d: Did you change the front/rear propshaft? I ask because of the known problem with vibration. cheers MK |
5th Dec 2008 1:17pm |
dave's 110 Member Since: 11 Jun 2008 Location: Norfolk Posts: 45 |
Got OME springs and shocks 1" lift but it's more like 2" lift rides and drives so much better not change any other parts and don't get any vibration at all have done 7000 miles with it lifted.
Dose not look to lifted take a look here this is it lifted up on OME springs http://www.saharanomads.com/atlanta_026.htm Dave |
7th Dec 2008 9:50am |
I only changed the springs I`ve got no vibrations from it yet |
8th Dec 2008 10:54am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Both our 110's are fitted with 2" lift OME springs. The Utility has a HD wide angle front prop.
8th Dec 2008 4:55pm |
just ordered my OME 2" lift from Devon 4x4 sod the Warranty if I stay with my 17" wheels what size mud terrain can I go for
12th Dec 2008 12:53pm |
ok just fitted the 2" OME kit to the 90 be back in five after a test drive see if I get the horrible gearbox chatter this time wish me luck
15th Dec 2008 9:12pm |
its back
but a much nicer drive over the standard setup I think ill call Devon 4x4 in the morning see what they think |
15th Dec 2008 9:50pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Bummer - let us know how you get on
15th Dec 2008 10:03pm |
