Home > Puma (Tdci) > Any lifted Pumas on here
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
has anyone on here jacked up there puma sucsessfully yet Neutral Question
Post #5223 2nd Dec 2008 9:52pm
Verdone
Belgium 2007 Defender 90 Puma 2.4 HT Java Black
Me and ive done i dont know maybe 10.000 km's on it and havent noticed anything wrong with it Laughing
Verdone
Post #5225 2nd Dec 2008 10:34pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Fed up with the front of the defender sagging i changed the front springs for Old Man Emu 751`s and the rear for Old Man Emu 755`s now she sits a lot more level Thumbs Up
Post #5230 2nd Dec 2008 11:24pm
simonpuma90
how much of a lift are these
Post #5233 3rd Dec 2008 8:46am
Sonic3d
They are a medium weight spring and lift it about 40 to 50 mm
Post #5237 3rd Dec 2008 10:54am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I can't remember who it was but somenone did suggest that you could use the landrover HD springs which give you about an inch lift. Which I think is a cracking idea as long as it does not make the ride to hard.
Post #5240 3rd Dec 2008 11:25am
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
The LR HD spring idea was probably me. I have done that and it works really well. You get a nice firm ride, great towing capacity, excellent control of the car and less body roll. The only thing I would say is that you might want to change the shocks to get the most of the car, for which I would recommend De Carbon as a general use one. I had them on my old off roading toy and they give a lovely ride quality.
I have a 110 double cab, so the rear sits high anyway with the XHD springs on which give you the 1 ton carrying capacity, so I did the fronts too as I have an ARB bumper fitted and they are heavy as heck. The front is now the same height as the rear and the ride and general drive is much better.
The really nice thing is that is will not void any warranty and will also not mean a change to your insurance either. They are nicely priced too. I think with my discount I got the pair for £65, so you should be looking at less than £150 for the set.
Landy nut
Post #5248 3rd Dec 2008 12:33pm
MK
Hi Sonic3d:
Did you change the front/rear propshaft? I ask because of the known problem with vibration.
cheers
MK
Post #5298 5th Dec 2008 1:17pm
dave's 110
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Stornoway Grey
Got OME springs and shocks 1" lift but it's more like 2" lift rides and drives so much better Thumbs Up not change any other parts and don't get any vibration at all have done 7000 miles with it lifted.
Dose not look to lifted take a look here this is it lifted up on OME springs http://www.saharanomads.com/atlanta_026.htm
Dave
Post #5321 7th Dec 2008 9:50am
Sonic3d
MK wrote:
Hi Sonic3d:
cheers
MK
I only changed the springs Very Happy I`ve got no vibrations from it yet Thumbs Up
Post #5337 8th Dec 2008 10:54am
AndrewS
Both our 110's are fitted with 2" lift OME springs. The Utility has a HD wide angle front prop.
Post #5345 8th Dec 2008 4:55pm
simonpuma90
just ordered my OME 2" lift from Devon 4x4 sod the Warranty Thumbs Up if I stay with my 17" wheels what size mud terrain can I go for
Post #5452 12th Dec 2008 12:53pm
simonpuma90
ok just fitted the 2" OME kit to the 90 be back in five after a test drive see if I get the horrible gearbox chatter this time wish me luck Rolling Eyes
Post #5532 15th Dec 2008 9:12pm
simonpuma90
its back Big Cry Big Cry Big Cry
but a much nicer drive over the standard setup I think ill call Devon 4x4 in the morning see what they think
Post #5535 15th Dec 2008 9:50pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Bummer - let us know how you get on
Post #5539 15th Dec 2008 10:03pm
