![]() | Home > Td5 > Lock Barrels |
I know all door barrels are interchangeable on the older style doors (s3) etc as fitted to the wolf fleet. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
yes lock barrels are interchangeable the only one you can not interchangeable steering column with doors barrels 2A onwards
Nick666 Member Since: 23 Mar 2016 Location: Somerset / Dorset borders! Posts: 81 ![]() ![]() ![]() |
... but you can get sets where the same key works on both doors and ignition. Haven't found one where the petrol cap works on the same but one day!
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 959 ![]() ![]() ![]() |
That my friend would be soooo... 1990s. LOL 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 172 ![]() |
There's a guide somewhere to change the lock in the petrol cap - you have to drill a small hole in the body of the cap to release the spring to take the old barrel out, then you can replace the barrel with one the same as in the doors. http://forums.lr4x4.com/index.php?showtopic=83226 Looks like it's pre-TD5 only though. A word of warning about the lock sets that all work off the ignition key - it looks like they take a lock set and re-grind the pins to fit the ignition key, rather than replacing the lock pins. This means that the locks aren't as secure as 'proper' locks and more likely to work with any key rather than just yours... |
