Home > Td5 > Lock Barrels
Simali
United Kingdom 2004 Defender 110 Td5 CSW Zambezi Silver
Lock Barrels
Does anyone know if the drivers door and tailgate lock barrels are interchangeable ? 2004 110 CSW (Called Yoda)
Post #552356 30th Jul 2016 11:10am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I know all door barrels are interchangeable on the older style doors (s3) etc as fitted to the wolf fleet. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #552358 30th Jul 2016 11:33am
dorsetsmith
yes lock barrels are interchangeable the only one you can not interchangeable steering column with doors barrels 2A onwards
Post #552365 30th Jul 2016 12:51pm
Nick666
United Kingdom 1986 Defender 90 2.5 n/a Diesel SW Yellow
... but you can get sets where the same key works on both doors and ignition. Haven't found one where the petrol cap works on the same but one day!
Post #552404 30th Jul 2016 5:19pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
That my friend would be soooo... 1990s. LOL 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #552515 30th Jul 2016 11:15pm
jonny
There's a guide somewhere to change the lock in the petrol cap - you have to drill a small hole in the body of the cap to release the spring to take the old barrel out, then you can replace the barrel with one the same as in the doors.
http://forums.lr4x4.com/index.php?showtopic=83226
Looks like it's pre-TD5 only though.
A word of warning about the lock sets that all work off the ignition key - it looks like they take a lock set and re-grind the pins to fit the ignition key, rather than replacing the lock pins. This means that the locks aren't as secure as 'proper' locks and more likely to work with any key rather than just yours...
Post #552525 31st Jul 2016 5:20am
