Home > Tdi > bulkhead for 300tdi |
George G Member Since: 02 Feb 2015 Location: Derbyshire Posts: 21 |
On a whole, yes it will fit - other than the vents its identical on the exterior surfaces and its structural connection's.
Will still need a little modification though - Recirculation vent in passenger footwell, No vents but most of the brackets are still there. Gearbox tunnel needs removing and r380 tunnel fixings adding Dash mounts are mostly the same but will need tweaking (top mounts under windscreen are the same) Wiper motor is in a different position. There is a cutout in the RH footwell (2.2 dpf cutout) so the clutch bracket overhangs and misses a fixing (easy fix with a puma clutch pedal, or just leave it...) The heater fan hole (between motor/matrix and the dash) is slightly different so will need opening up. Oh and the heater matrix is inside the cab on a puma so that hole needs plugging and the one in the centre will need plating over. (I have made a gland plate for the original loom that bolts in place for easy removal) [URL=] Click image to enlarge[/URL] Lots of little jobs but nothing too hard. Probably best not to buy a galvanised one, but to get it done afterwards. Good luck :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
27th Jul 2016 9:38pm |
horus1970 Member Since: 27 Jul 2016 Location: north east Posts: 105 |
thanks mate that was egsactly everything I was concerned about, doesn't sound too bad, cheers
28th Jul 2016 10:42pm |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 627 |
It is a long short but they were still welding up bulkheads at the factory in January that had vent holes as well as ones without. Is your source only able to get them without vent holes?
And the price of bulkheads seem unchanged from 1987 when I got a price for a Series III one. 1995 Defender 110 CSW 1971 SIIA Lightweight |
29th Jul 2016 8:24am |
there advertised on fleabay for 750 but there are no vent holes in, havnt seen any with them in for sale anywhere else mate.
29th Jul 2016 11:15pm |
Lotus_esprit_s1 Member Since: 01 Oct 2014 Location: Uk Posts: 201 |
I bought two new bulkheads with vents two months ago. Mfg date on the door posts was 2016.
They seem to be a strange hybrid with the wiring loom holes and heater holes being for a puma though. I bought a previous one last November and it was a correct late td5 one They were approx £1200 each. I bought two while they were still available. |
30th Jul 2016 11:03pm |
thanks for that lotus esprit much appteciated,
6th Aug 2016 1:35pm |
