Home > Technical > 2003 TD5 Double Cab - Running / Starting problems
Page 2 of 3 <123>
mk1collector
You have to unplug the red plug and look at the terminals. Ray
My build thread
Post #550257 21st Jul 2016 4:33pm
dorsetsmith
yes you find the oil if you unplug it
your can use brake cleaner to flush out oil
Post #550258 21st Jul 2016 4:34pm
Skelkelly
United Arab Emirates
Doh!
Will take another look!
Post #550261 21st Jul 2016 4:48pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
As I said before if lots of white smoke probably injector seals and washers not that expensive to have done would be first port of call if no difference when maf unplugged 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #550288 21st Jul 2016 6:20pm
Skelkelly
ECU full of oil...
Post #551641 27th Jul 2016 4:23pm
Skelkelly
Which is bloody annoying as the dealer promised me they would check this prior to me having it.
Post #551643 27th Jul 2016 4:26pm
dorsetsmith
Are they going repair and replace under warranty Exclamation
Post #551645 27th Jul 2016 4:30pm
mk1collector
Take it back and get them to change the injector loom and clean out all the ecu plug. Ray
My build thread
Post #551658 27th Jul 2016 4:48pm
Skelkelly
They're too far from me to take it back, unlikely they'd do anything anyway...
http://forum.landrovernet.com/showthread.p...s-bradford
Shouldn't cost me too much and I'm going to go for a warranty claim, hopefully will get it covered.
Just glad it's nothing more serious to be honest!
Thanks for all the replies.
Post #551752 27th Jul 2016 9:44pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
did you disconnect it and look into the contacts? they can look dry on the outside and be literally ringing wet inside with oil.
I'd check RM the seals and the fuel pressure. I'd also plug it in and make sure the crank signal etc is fine too. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #551796 28th Jul 2016 6:29am
dorsetsmith
injector loom replacement TD5 red plug clean out
http://www.discovery2.co.uk/Injector_harness.html
Post #551827 28th Jul 2016 8:49am
Skelkelly
It's in the garage at the mo, had a new loom. Apparently there was a lot of oil in there.
Post #551859 28th Jul 2016 11:21am
Skelkelly
At least it's given me a chance to get the old girl out...
She feels like a jet fighter compared to the Defender!
Post #551860 28th Jul 2016 11:25am
mk1collector
The red plug will probably need cleaning out about once a week for the next month or two as some oil will still be coming down the main loom. Ray
My build thread
Post #551877 28th Jul 2016 12:25pm
dorsetsmith
Had same problem with my 03 about one month clear out oil from main loom
Post #551885 28th Jul 2016 12:54pm
Page 2 of 3 <123>
