Home > Technical > Cruise control closest to OE |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
I have a Nakatenanga one - looks and works great
The Mobilecentre one is incredibly similar but cheaper... see http://www.defender2.net/forum/topic38021.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) Last edited by MartinK on 26th Jul 2016 1:52pm. Edited 1 time in total |
26th Jul 2016 1:51pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3763 |
Do the pictures on this link help?
Have to say I'm currently going away and its one of the only things I might miss on my other car for the long journey How much would fitting one of these cost? http://www.defender2.net/forum/post432461.html |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
Click image to enlarge Finding a cc that looks OE in a Defender is pretty difficult, as some look way too modern and refined for it, in my view. I rather like the clutter of stalks created when adding one to the left hand side of the column. It works perfectly, is easy to fit and doesnīt cost much. A cc really is one of the most useful mods you can do to a TD4, unless it spend all its time on a farm or rescueing people off mountains, and it is as close to autonomous motoring as I want my Defender to achieve . Mine is the Terrafirma /Nakatanenga one (without memory) and cost about GBP 350.00. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
26th Jul 2016 6:17pm |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1972 |
Nice I wonder if an indicator stalk could be reworked to perform the same function and then have appropriate graphics added. I'm trying to recall the cc on my old P38, I think it had an on off switch on the dash. Could do something similar.
26th Jul 2016 7:27pm |
Here is a link to a half decent image of the Terrafirma product. The stalk and font look quite OE to my eye. http://www.frogsisland4x4.com/cruise_controlTD4?search=Cruise
26th Jul 2016 8:05pm |
steve_c3 Member Since: 30 Apr 2015 Location: Hants Posts: 173 |
Here's mine, it's not a Puma but is technically OE (from a Disco) and to be honest you don't even notice its there. Whichever you choose, it's one of the best mods you can make especially if you spend a lot of time cruising.
Click image to enlarge 2002 Defender 110 CSW TD5 |
26th Jul 2016 8:14pm |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
To keep the factory feel including the markings the right way up this is my set up...
https://www.defender2.net/gallery/albums/u...C11447.JPG From this thread with a few pictures of other options also... http://www.defender2.net/forum/topic15611.html Cheers, Kyle. |
27th Jul 2016 12:48am |
I fitted the Mobile Centre one over the weekend and I have to say I think it looks good and performs well.
At low RPM in high gears (where you shouldn't really be anyway) it can sometimes hunt a little but that's the only flaw I've found so far. It needs to be fitted on the left of the dash so that the light faces towards you and so that flicking it up increases the speed, and I've got it just above the headlight switch. It's really easy to use, you turn it on when you want to start using it by pushing it away from you. Then if you want to activate it you flick it up, change speed by flicking up or down, pause by pulling it towards you, resume by flicking down or set a new cruise speed with up (those last two might be backwards, I forget). I haven't used the speed limiter or either of the pre-set speeds yet. This thread was helpful with the fitting but it's possible to do with just the instructions: http://www.defender2.net/forum/topic39904.html Contact Tim for a price. |
27th Jul 2016 6:13am |
