![]() | Home > Td5 > What's the connection on the airbox for? |
ambient air sender is in the in side of the air filter box
texet7 Member Since: 05 Jul 2016 Location: East Riding of Yorkshire Posts: 14 ![]() ![]() ![]() |
Thanks. Is this like a flow or temperature sensor? What'd be the affect of unplugging this 2003 Defender TD5 90
temperature sensor What'd be the affect of unplugging ecu will not be able to read amb air temp
MAF is the next one between air filter box and the turbo |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
It's the atmospheric pressure and temperature sensor. You need it as it gives the ECM the base line reference for boost pressure.
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
I wouldn't personally the oil from the k &n might damage the airflow meter. I removed the k&n panel filter from mine incase and ive not refitted it 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
