Home > Td5 > What's the connection on the airbox for?
texet7
United Kingdom 2003 Defender 90 Td5 HT Corris Grey
I was considering doing an experiment and basically removing the air box and replacing it with a K&N conical filter connecting straight to the MAF. In theory that should work just fine and whether it's beneficial or not is still down to testing as i've never seen it done. The only thing i've noticed though before doing it is this connection to the airbox. I just wanted to know what it does and will disconnecting it put it in limp mode or have any affect really. Thanks, image below
Post #550270 21st Jul 2016 5:38pm
dorsetsmith
ambient air sender is in the in side of the air filter box
Post #550282 21st Jul 2016 6:09pm
texet7
Thanks. Is this like a flow or temperature sensor? What'd be the affect of unplugging this 2003 Defender TD5 90
Post #550284 21st Jul 2016 6:13pm
dorsetsmith
temperature sensor What'd be the affect of unplugging ecu will not be able to read amb air temp
MAF is the next one between air filter box and the turbo
Post #550285 21st Jul 2016 6:15pm
Fatboy Slim
Wales
It's the atmospheric pressure and temperature sensor. You need it as it gives the ECM the base line reference for boost pressure.
Post #550598 23rd Jul 2016 10:03am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I wouldn't personally the oil from the k &n might damage the airflow meter. I removed the k&n panel filter from mine incase and ive not refitted it 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #550637 23rd Jul 2016 1:35pm
