Home > Td5 > Oil!
miker
Oil!
What are people using?
Mine's done a fair few thousand miles since I replaced the engine, so I figure it deserves an oil change, especially as I have a load of miles to do over the next couple of months heavily laden. Probably going to do both oil filters as well for the sake of completeness. The previous owner of the engine changed it very frequently, to the extent that the oil still looks pretty golden! I intend to keep it in similar good condition.
Also going to drain and refill the t/box and diffs, they've only been topped off since I've had it, so figure a full drain and refill won't go amiss.
Post #549702 19th Jul 2016 10:39am
X4SKP
Hello miker Castrol Specifications for a TD5
Engine / Transmission / Differentials / Steering...
If you like Castrol (I do) this is a good selection tool for the Defender Types... Thumbs Up
http://applications.castrol.com/oilselecto...1998-2007) SKIP
Post #549709 19th Jul 2016 11:00am
dorsetsmith
7.2 ltr oil engine Exclamation with filter
Post #550361 22nd Jul 2016 7:48am
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Magnatec A5 is ACEA rated for petrol engines Confused
Quote:
ACEA
This is the European equivalent of API (US) and is more specific in what the performance of the oil actually is. A = Petrol, B = Diesel and C = Catalyst compatible or low SAPS (Sulphated Ash, Phosphorus and Sulphur).
Unlike API the ACEA specs are split into performance/application catagories as follows:
A1 Fuel economy petrol
A2 Standard performance level (now obsolete)
A3 High performance and/or extended drain
A4 Reserved for future use in certain direct injection engines
A5 Combines A1 fuel economy with A3 performance
B1 Fuel economy diesel
B2 Standard performance level (now obsolete)
B3 High performance and/or extended drain
B4 For direct injection car diesel engines
B5 Combines B1 fuel economy with B3/B4 performance
Post #550363 22nd Jul 2016 7:53am
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
A, B, pretty indistinguishable nowadays...
Looking at some Magnatec with 5W-30 A1 on the big label, the small print reads SAE 5W-30, ACEA A1/B1, A5/B5; Meets Ford WSS-M2C913-A, WSS-M2C913-B, WSS-M2C913-C.
Oil is oil, but at least with Castrol you get the occasional offer of 4 litres for twenty quid or so from Asda, and guaranteed new and not collected from garages, reycycled and repackaged...
Peter
Post #550367 22nd Jul 2016 8:10am
miker
Cheers for the thoughts! The other suggestion I've seen is VW 505 01 spec oil, as the TD5 is a unit injector engine, much like the volkswagen PD diesels (which I also have one of) And thus the oil requirements are similar.
Post #550400 22nd Jul 2016 10:12am
