Home > Td5 > Oil! |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello miker Castrol Specifications for a TD5
Engine / Transmission / Differentials / Steering... If you like Castrol (I do) this is a good selection tool for the Defender Types... http://applications.castrol.com/oilselecto...1998-2007) SKIP https://www.defender2.net/forum/topic83242.html |
19th Jul 2016 11:00am |
7.2 ltr oil engine with filter
Click image to enlarge Click image to enlarge Last edited by dorsetsmith on 22nd Jul 2016 8:13am. Edited 2 times in total |
22nd Jul 2016 7:48am |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
Magnatec A5 is ACEA rated for petrol engines
22nd Jul 2016 7:53am |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 865 |
A, B, pretty indistinguishable nowadays...
Looking at some Magnatec with 5W-30 A1 on the big label, the small print reads SAE 5W-30, ACEA A1/B1, A5/B5; Meets Ford WSS-M2C913-A, WSS-M2C913-B, WSS-M2C913-C. Oil is oil, but at least with Castrol you get the occasional offer of 4 litres for twenty quid or so from Asda, and guaranteed new and not collected from garages, reycycled and repackaged... Peter |
22nd Jul 2016 8:10am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
Cheers for the thoughts! The other suggestion I've seen is VW 505 01 spec oil, as the TD5 is a unit injector engine, much like the volkswagen PD diesels (which I also have one of) And thus the oil requirements are similar.
22nd Jul 2016 10:12am |
