Home > In Car Electronics > Switches needed |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
Devon4x4 or Mudstuff.co.uk http://www.yorkshireoffroadclub.net/
20th Jul 2016 11:44am |
neil5886 Member Since: 15 Feb 2016 Location: York Posts: 24 |
Thanks I'll have a look.
20th Jul 2016 12:07pm |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 |
One thing to bear in mind is that, at least the mud ones work the American way - so you push them in at the top to turn them on. I really didn't like that and returned them - the only place I found that had the working the 'U.K.' way was Croytec I think.
You can read about it here: http://forums.lr4x4.com/index.php?showtopic=64589 |
20th Jul 2016 12:25pm |
Mudstuff offer both US and EU options, not sure when they started offering them though, it's a relatively new option I think.
The EU version switch on when you press the bottom, the US ones switch on when you press the top. http://www.yorkshireoffroadclub.net/ |
20th Jul 2016 12:49pm |
As I am unsure where to put the switches yet, i'm thinking to the right of the dash i'm not too bothered which way the switches operate as long as I can wire them up correct.
20th Jul 2016 1:01pm |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
I think genuine Landrover switches look better but expensive 2020 P300 HSE
20th Jul 2016 1:02pm |
Do the genuine ones come with different, markings showing which switch does what.
20th Jul 2016 1:04pm |
That's good to know ! |
20th Jul 2016 1:08pm |
You can get a light switch with a no 2 on it but after that I think you will struggle although if in Aussie they do these
http://www.expeditioncentre.com.au/online-...wards.html http://www.expeditioncentre.com.au/online-...panel.html 2020 P300 HSE |
20th Jul 2016 1:59pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
I found mobile centre to have the best options for carling switches. They also supply them all as european type switching.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
20th Jul 2016 2:54pm |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 719 |
If you don't fancy cutting your dash, how about one of these:
http://m.ebay.co.uk/itm/231848689785?_mwBanner=1 Think it fits in next to the steering column. They can supply switches too which look similar to Carling switches, but not sure if they need the same size hole or not. if you definitely want Carling switches, might be worth asking them if they'll supply one without the hole cut in it so ou can cut it to your needs. |
20th Jul 2016 3:40pm |
I have looked at that, although unsure on how to get the wires there,
Not too bothered about them been Carling switches, I had the switches from bolt on bits in my last 110. |
20th Jul 2016 3:43pm |
Flyingfocrs Member Since: 12 Jan 2015 Location: Deepest darkest Aberdeenshire Posts: 155 |
I bought one of these but it didn't fit, be interested to know if anyone else has tried one? Ended up just cutting a hole in the front of the cubby. [URL=] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
20th Jul 2016 4:20pm |
Thats not good, did you take it up with the shop about it not fitting
21st Jul 2016 8:09am |
