Home > In Car Electronics > Switches needed
neil5886
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Indus Silver
Switches needed
As soon as I find time, i play on finally fitting, my led lightbar and for the front and rear of my Puma.
Where is the best place to buy Carling rocker switches from.
Post #549952 20th Jul 2016 11:20am
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Devon4x4 or Mudstuff.co.uk http://www.yorkshireoffroadclub.net/
Post #549959 20th Jul 2016 11:44am
neil5886
Thanks I'll have a look.
Post #549962 20th Jul 2016 12:07pm
Anderzander
One thing to bear in mind is that, at least the mud ones work the American way - so you push them in at the top to turn them on. I really didn't like that and returned them - the only place I found that had the working the 'U.K.' way was Croytec I think.
You can read about it here: http://forums.lr4x4.com/index.php?showtopic=64589
Post #549966 20th Jul 2016 12:25pm
davew
Mudstuff offer both US and EU options, not sure when they started offering them though, it's a relatively new option I think.
The EU version switch on when you press the bottom, the US ones switch on when you press the top. http://www.yorkshireoffroadclub.net/
Post #549971 20th Jul 2016 12:49pm
neil5886
As I am unsure where to put the switches yet, i'm thinking to the right of the dash i'm not too bothered which way the switches operate as long as I can wire them up correct.
Post #549973 20th Jul 2016 1:01pm
pjb
I think genuine Landrover switches look better but expensive 2020 P300 HSE
Post #549975 20th Jul 2016 1:02pm
neil5886
Do the genuine ones come with different, markings showing which switch does what.
Post #549976 20th Jul 2016 1:04pm
Anderzander
That's good to know !
Post #549978 20th Jul 2016 1:08pm
pjb
You can get a light switch with a no 2 on it but after that I think you will struggle although if in Aussie they do these
http://www.expeditioncentre.com.au/online-...wards.html
http://www.expeditioncentre.com.au/online-...panel.html 2020 P300 HSE
Post #549992 20th Jul 2016 1:59pm
rallysteve
I found mobile centre to have the best options for carling switches. They also supply them all as european type switching.
Post #550004 20th Jul 2016 2:54pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
If you don't fancy cutting your dash, how about one of these:
http://m.ebay.co.uk/itm/231848689785?_mwBanner=1
Think it fits in next to the steering column. They can supply switches too which look similar to Carling switches, but not sure if they need the same size hole or not. if you definitely want Carling switches, might be worth asking them if they'll supply one without the hole cut in it so ou can cut it to your needs.
Post #550016 20th Jul 2016 3:40pm
neil5886
I have looked at that, although unsure on how to get the wires there,
Not too bothered about them been Carling switches, I had the switches from bolt on bits in my last 110.
Post #550017 20th Jul 2016 3:43pm
Flyingfocrs
Scotland 2011 Defender 110 Puma 2.4 USW Santorini Black
I bought one of these but it didn't fit, be interested to know if anyone else has tried one?
Ended up just cutting a hole in the front of the cubby.
Post #550033 20th Jul 2016 4:20pm
neil5886
Thats not good, did you take it up with the shop about it not fitting
Post #550157 21st Jul 2016 8:09am
