Home > Technical > Hydraulic Power steering on 110 |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
That looks decidedly home made
Nothing to do with Land Rover Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
15th Jul 2016 12:58pm |
RobertJ Member Since: 18 Mar 2015 Location: Italy Posts: 16 |
It is a Hydraulic power steering steering system for Series and Defenders [2015] Land Rover Defender 2.2 TD SW 110 X-Tech
[1986] Land Rover 110 2.5 N/A Soft Top Last edited by RobertJ on 15th Sep 2016 4:24pm. Edited 1 time in total |
15th Jul 2016 1:15pm |
Depends how far you want to go.
If you want to keep it fairly original then just remove it and keep it as non power steering. Not sure what should be there but I don't remember there being anything there on a standard 2.5n/a I'm not sure if there was a power steering option for the 2.5na but I would be surprised if there was not. parts may be prohibitively expensive though. If it was me, I would find a old 200Tdi Discovery and fit the engine, Intercooler etc into yours and use a standard defender power steering setup. Much easier for future maintenance and will give the vehicle a new lease of life as the 2.5n/a is a bit of an agricultural lump - but will go on forever! I wouldn't really want to chance with the setup as is. I'm sure it is fine and has been on there for years but there is a lot of weight there and that ram looks capable of putting a huge amount of force if it was to go wrong. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
15th Jul 2016 1:27pm |
http://www.allbrit.de/UNI.cfm?PAGE=746902&SPRACHE=EN
show power steering for 2.5 n/a but parts may be a problem |
15th Jul 2016 1:35pm |
True, I have thought about fitting a 200Tdi but I want this one to be fairly original and I like the tractor like diesel I bought it for toddling (it that even an english word?) through town and the surroundings. [2015] Land Rover Defender 2.2 TD SW 110 X-Tech [1986] Land Rover 110 2.5 N/A Soft Top Last edited by RobertJ on 15th Sep 2016 4:25pm. Edited 1 time in total |
15th Jul 2016 1:40pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1762 |
I can't find the link from my phone, but it is possible to buy retrofit power steering kits for series vehicles. That looks pretty similar to those, so may just be an aftermarket kit been fitted? Although obviously not original, it looks fairly proper!
15th Jul 2016 2:16pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17209 |
That is an aftermarket PAS system of a fairly conventional design.
15th Jul 2016 2:49pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2222 |
Have seen similar before fitted to forrestry series/pre defenders which were fitted with large agri-tyres or tracks. Think it was possibly used to stop the large wheels bending the front steering link in boggy ground and possibly as the standard PAS didnt provide enough assistance. 02' 110 TD5 Double Cab Rebuild Thread
15th Jul 2016 3:39pm |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 818 |
Hydro assist is quite commonplace in the challenge scene, most use a similar principle to what you have got, modern versions are available front the likes of Gwynn Lewis though to full hydro steer systems.
If it works I'd leave it as it does look a period modification and will be a lot better than no power steering |
15th Jul 2016 4:45pm |
Andy80 Member Since: 31 May 2013 Location: Essex Posts: 490 |
It looks very similar to the Heystee Automotive kit...
http://www.heystee-automotive.com/parts/pas/pas.htm Working towards Carry on camping! |
15th Jul 2016 6:21pm |
I've no idea about your steering but that's a perfect use for the English word "toddling". Bumbling around slowly and not necessarily in the most direct route. A child learning to walk is often called a toddler. |
15th Jul 2016 6:53pm |
giles Member Since: 21 Jan 2013 Location: 81600 Posts: 8 |
Calzoni steering kits used to be a popular add-on to series vehicles (here in France at any rate). Not so common to see on a 90/110
16th Jul 2016 12:53pm |
Glad to hear that
Then I am not so surprised it is indeed a Hydraulic power steering set for Series and Early Defenders, thanks! [2015] Land Rover Defender 2.2 TD SW 110 X-Tech [1986] Land Rover 110 2.5 N/A Soft Top |
22nd Jul 2016 9:50am |
