Home > Off Topic > Foolish or otherwise
Page 3 of 3 <123
PDH
BigMike wrote:
PDH, which brodit are you using? I can see the ipad housing thing itself, but am wondering how youre attaching that to the dash, and where.
BigMike - use this link http://www.dsldevelopments.com/brodit/hold...Holder.asp and it gives you 2 mounting bracket options depending on where you want to postiion the ipad.
I went for the side mount, the pic below shows the final location of the ipad using the bracket as it arrives. Ive since modified the bracket to move the ipad higher up the dash so its easier to read memory maps on the move
Since the mod the top of the ipad sits in line with the top of the clock
 Puma 2.2 90 Stationwagon
Post #54891 25th Jan 2011 12:11am
mse
How do you find it with the heat - ive specifically chosen to avoid that area...which is difficult with the mount i have Mike
Post #54893 25th Jan 2011 12:24am
PDH
I've not had any issues to date and have been running with it in that position for some months now, i never have the round vents on anyway so its just the flow from the square central ones. Puma 2.2 90 Stationwagon
Post #54897 25th Jan 2011 6:58am
mse
Interesting thanks - i was concerned about the heat - especially as apple warn about it Mike
Post #54969 25th Jan 2011 4:51pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
The iPad is quite prone to overheating.
I was working on mine in the garden over the summer and it suddenly switched off and just showed the following warning Rolling with laughter
No damage done - they soon start up again.
 One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #55029 25th Jan 2011 9:20pm
BigMike
Cheers PDH. Is the mounting clip you used this one?
Post #55093 26th Jan 2011 10:00am
Page 3 of 3 <123
