Home > Off Topic > Foolish or otherwise |
PDH Member Since: 03 Dec 2009 Location: Shropshire Posts: 179 |
BigMike - use this link http://www.dsldevelopments.com/brodit/hold...Holder.asp and it gives you 2 mounting bracket options depending on where you want to postiion the ipad. I went for the side mount, the pic below shows the final location of the ipad using the bracket as it arrives. Ive since modified the bracket to move the ipad higher up the dash so its easier to read memory maps on the move Since the mod the top of the ipad sits in line with the top of the clock Click image to enlarge Puma 2.2 90 Stationwagon |
25th Jan 2011 12:11am |
I've not had any issues to date and have been running with it in that position for some months now, i never have the round vents on anyway so its just the flow from the square central ones. Puma 2.2 90 Stationwagon |
25th Jan 2011 6:58am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5055 |
Interesting thanks - i was concerned about the heat - especially as apple warn about it Mike |
25th Jan 2011 4:51pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
The iPad is quite prone to overheating.
I was working on mine in the garden over the summer and it suddenly switched off and just showed the following warning No damage done - they soon start up again. Click image to enlarge One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
25th Jan 2011 9:20pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Cheers PDH. Is the mounting clip you used this one?
26th Jan 2011 10:00am |
