Home > Td5 > Alarm interior movement sensor ! |
Click image to enlarge |
14th Jul 2016 3:55pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
Do you have remote central locking? If so, simpy lock the door with the key, not the remote.
14th Jul 2016 4:03pm |
Simplest solution is to stick some insulation tape over the perimetric sensor.
http://www.defender2.net/forum/topic38997....perimetric http://www.defender2.net/forum/topic7681.h...perimetric http://www.defender2.net/forum/topic8354.h...perimetric If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
14th Jul 2016 7:48pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
Or if yoy never want to use it. Unclip it from the headlining and unplug it. You can put it back afterwards.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
14th Jul 2016 7:54pm |
Simali Member Since: 25 Jun 2015 Location: Basingstoke Posts: 46 |
I dont have a key to to fit the drivers door so looks like I need to get one. Will try tape for nk
Simon 2004 110 CSW (Called Yoda) |
15th Jul 2016 6:27am |
ok re your other post door lock
15th Jul 2016 7:41am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 933 |
Simali, it will honk twice but still set the alarm afterwards. Once you close the drivers door the volumetric sensor will now be deactivated amd the alarm will sound only if a door or bonnet is opened. It does work. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
15th Jul 2016 11:45pm |
