Home > Puma (Tdci) > Oil Filter cup leaking following oil change |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4169 |
I had to swap the fillet only a couple of weeks ago. Not much oil company comes out, maybe 250ml, athlough it feels like a lot more when it is trickling down your sleeve!
13th Jul 2016 8:49pm |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 |
What did you swap the fillet for? Sirloin or maybe a nice bit of cod?
AlanH. |
14th Jul 2016 9:53am |
It was Fillet 'O Fish, and I swapped it for McNuggets if you must know!
14th Jul 2016 11:39am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Did you replace the O ring into the correct groove in the filter canister? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
14th Jul 2016 1:13pm |
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 |
Oh yes, all done right - as I said, I suspect either the o-ring failed or the bowl has cracked. Will know why on Saturday once I get it off. Was just curious to how much new oil I'd lose so I can make sure I have enough to top up afterwards.
Cheers Mark |
14th Jul 2016 2:43pm |
get your self spare one i.e o ring and bowl
LR004508 or fords part number 1303477 |
14th Jul 2016 3:02pm |
