Home > Puma (Tdci) > Oil Filter cup leaking following oil change
vaucluse
2007 Defender 110 Puma 2.4 SW Java Black
Gents,
Having just changed the oil and filter at the weekend I've noticed the plastic oil filter cup is leaking. Either the cup has cracked or the new rubber o-ring, despite being well oiled, has failed.
My question to you is, if I leave the sump filled with oil and just undo the filter cup, how much oil could I expect to lose? Every time I change the oil and filter I've always drained the sump first and then undone the filter so have no experience of doing other way around.
Mark
Post #548552 13th Jul 2016 7:42pm
Bluest
I had to swap the fillet only a couple of weeks ago. Not much oil company comes out, maybe 250ml, athlough it feels like a lot more when it is trickling down your sleeve!
Post #548556 13th Jul 2016 7:49pm
AlanH
Australia
What did you swap the fillet for? Sirloin or maybe a nice bit of cod? Laughing
AlanH.
Post #548662 14th Jul 2016 8:53am
Bluest
It was Fillet 'O Fish, and I swapped it for McNuggets if you must know! Very Happy
Post #548686 14th Jul 2016 10:39am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Did you replace the O ring into the correct groove in the filter canister? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #548714 14th Jul 2016 12:13pm
vaucluse
Oh yes, all done right - as I said, I suspect either the o-ring failed or the bowl has cracked. Will know why on Saturday once I get it off. Was just curious to how much new oil I'd lose so I can make sure I have enough to top up afterwards.
Mark
Post #548727 14th Jul 2016 1:43pm
dorsetsmith
get your self spare one i.e o ring and bowl Exclamation
LR004508 or fords part number 1303477
Post #548732 14th Jul 2016 2:02pm
